Hi Alan,
A while ago I had a similar application and looked into a hitch crane. They are quite simple and can typically be found inexpensively (less than $200). The ones I was looking at didn\'t have the reach you need, but could easily be modified to fit your needs.
I think PVC might be on the weak side to lift the dinghy. 2x4s would certainly work, but may be somewhat cumbersome. Some 1.5" conduit or water pipe might be a better bet if you\'d prefer to make something of your own design.
Cheers,
Matias
AlbinVega@yahoogroups.com [
AlbinVega@yahoogroups.com]
Sent: Tuesday, September 15, 2015 10:25 AM
To:
Subject: [AlbinVega] Raising And Lowering A Dinghy For Transport On Top Of Pickup Truck Cap
I\'m about to install a roof rack on the cap of my pickup truck. The top of the rack will be about 85 inches high. The dinghy weighs >100 pounds. I\'m sure that I\'m not the first geezer to confront this problem. Has anyone seen any solutions online or have
any ideas. One requirement is that I carry whatever tools I need to raise and lower the dinghy.
I\'ve thought of making a gantry of PVC pipe but have no idea of what will be strong enough. Same for 2x4 or larger of wood. The dimension from the gunwale to the bottom is ~2 feet and the clearance will be slightly higher than that due to the sheer. The
height of the top member of the gantry would need to be at least 10 feet.
I\'ve considered 2 2x4s leaning on the side of the truck and sliding the dinghy up or down. For the up drama one person would push and the other would pull on a line from the far side. If the 2x4s were 10 feet long then the angle of the slope would be ~45°.
Any ideas??
thanks,,,
Alan
#ygrps-yiv-509382510 {direction:ltr;font-family:Tahoma;color:#000000;font-size:10pt;}#ygrps-yiv-509382510 P {margin-top:0;margin-bottom:0;}#ygrps-yiv-509382510 {}#ygrps-yiv-509382510 {}#ygrps-yiv-509382510 {}#ygrps-yiv-509382510 {}
