J. Barrett
Does anyone know how the rudder on an M25 is supposed to work. There are two lines attached to mine. One is apparently a downhaul that runs through a block on the rudder castle and secures to a cleat on the castle itself and seems to work ok. The other runs from the rudder blade to a block on the stern rail and is supposed to haul the rudder up (again secured to the cleat when raised). Lowering the rudder is not much of a problem. I occasionally will reach down with my foot and push while pulling on the downhaul. Down she goes and I go sailing. Reversing this isn't quite as easy. Occasionally I can get the blade to at least come to the surface. Most of the time I need to motor forward some to coax it up. Hauling it from the water requires an act of Congress. Usually I end up lassoing it with another line to hoist it up. My opinion is that the line to lift it needs to be attached alot further down the blade to allow some mechanical leverage. This set-up came with the boat and I see no signs of any prior attachment further down the blade. Any ideas? Thanks. -John
