Rain water thru the mast
Michael
Anybody has an idea, how to stop rainwater getting in thru the Sparecraft mast? Where can the water get in? I sealed all over the deck-opening where the mast gets thru. Mike
Jun 1, 2004
227
Beneteau 393 Newport
More than likely,
the rain is coming down the slot in the mast that are for the sail lugs. It is a good size hole. The other entrances are at the top of the mast where your halyards exit the mast. I would recommend putting a Spartite seal around the mast. It will not only seal the water out, but it will ensure that the mast remains in column since it replaces the wedges. Jim
