Just discovered that the antifreeze overflow container and hose is not working. The hole into the radiator cap throat was never drilled thru. Filled engine with 50/50 mix, boiled some out. Have enuff on board for the two more travel days till home, butfilling and boiling A/F away doesn't seem like the long term solution. Any thoughts?
