Even WITH dacron there is a performance advantage
in a radial cut jub/genoa.I build my own dacron jibs/genoas with radial cuts but with heavier cloth at the leechs and lighter weight cloth at the luff. 1. You dont need the heavier cloth at the luff especially when partly furled/reefed and simply leave the heavier weight leech exposed. 2. With roller furling/reefing and with "two" cloth weights, you will get a better/tighter 'roll' on the foil and will be able to reduce down past the 'normal' 30% LP of *single weight* sails. For racing, there is no choice other than straight laminate (Spectra, etc.) but for adjustability and *long life* go with woven dacron. For cruising, less sails onboard mean more 'stores'. With woven dacron you still have 'adjustability' for shaping (halyard tension or auxilliary cunningham,etc.) but not as much as with a cross-cut. I still prefer 'top of the line' woven dacron over "laminate center layer with dacron taffeta on-top". With woven dacron you can fold it, wash/clean it, easily re-cut it, etc. If long distance cruising, consider cross-cut sails made from top-shelf 'woven' dacron. Dont skimp with cheap materials.
