Roan
I currently have 2006 Hunter 33 with Raymarine ST 60 gauges and C-80 chart plotter. I am looking to add radar for next year trip around Maine coast. Travel down from Lake Champlain then up! Where to place the dome. Most people put it on the mast above first spreader to the height of one length of cable. ( Cable expensive so they do not go higher). I am now being told I should consider a stern pole mount for the radar. That is not as high as mast. So I assume less range coverage. There are complaints about the dome being hit by fore sails when on mast. If I go for a pole on stern, are there telescoping poles so that I could lower it when going under bridges on canals like Champlain canal ( 13 ft clearance)? Or am I better to put on mast. Any input appreciated.
