radar
Hunter 33 Bennington VT
I have a Hunter 33 2005 and I would like to add a radar to the arch . Any advise would be great.
Alain
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Alain, Given that the mainsail traveler is mounted on top of the arch I don't see any way to accomplish this. You could probably have an auxiliary arch mounted behind the original which would clear both the traveler and the boom. I would opt for the antenna to be mounted on its own stalk if you have to have radar.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
That's pretty low. You would want to keep people off the deck forward of the cockpit when it was operating. A bow lookout can be a nice thing to have in thick conditions. The radar will also see farther and have less sea clutter if you put it up on the mast.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
No Way
That is not possible as already mentioned it is either up the mast or on a pole mounte on the stern or spend tons of $$$$$ for another arch.
I have the raar up the mast from the factory on my H-36.
Nick
Oct 29, 2005
2,366
My friend's H-33 and another have it on the Mast somewhere between the two spreaders. You'll need to buy extension cables as I don't think the ones that comes with Raymarine would be long enough (that is if you're planning on using Raymarine).
