Vertical Beam Angle
This is the same concern I had. Our radar is mounted on a mast at the stern. Height of the radar dome is high enough so that given the plus/minus 20 degrees or so it will clear the heads of anyone in the cockpit, and then some. The mast was put up "temporarily" about eight years ago for a major trip, with braces at about 90 degrees to the pushpit and has worked well. However, when (if ever) I install it permanently it will be slightly different. The 1-inch railing of the pushpit is lightly attached to the boat with small bolts, say 1/4 or 5/16-inch, welded at the base of each tube, probably spot welded. This doesn't seem to be the most secure setup so rather than guying the mast off to the rail I'd prefer to guy it off to the deck reinforced with backing plates. If the mast would be used for other purposes, such as a motor lift, this would be the preferred anchoring system.The stern mast could be either a hinderance or help in the case of a bimini or full length dodger.With our setup, the stern mast is an advantage for the installation of a man-overboard horseshoe with drogue coupled with a marker buoy. The marker buoy has a high pole which is partially supported by a bracket off the mast. To complete our setup I plan to attach a small radar reflector on the marker buoy and add some more light reflector tape.
