G
Gary Wyngarden
Hi gang,I purchased a JRC 1500 Radar at the Seattle Boat Show for my 1992 Hunter 335. Since then I've been evaluating mounting alternatives and have reached a tentative conclusion which I'd like to get some feedback on.1. Mast Mount. Based on observation at a few marinas and also an article in Practical Sailor, this seems to be by far the most popular alternative. However, I've got a 135 genoa and believe both the radar and the sail will get beat up every time I tack. The radar could be protected, but probably not the sail. Also the opportunity for fouling lines is there and the complexity of running the cables to the display unit seem a bit high.2. Backstay mount. This was my first choice--specifically the split backstay mount from the chandlery on this site. However, the guy who sells the backstay mount says you have to tighten the backstays to provide the rigidity for an effective mount. He recommends this only if your forestay goes to the top of the mast. The H335 has a fractional rig.3. Pole mount on the stern with a bracket on the pulpit. I'm not wild about this because it adds clutter around the cockpit but have concluded that it's the "least worst" option. I'm thinking maybe Garhauer with a gimballed mounting bracket on the platform and a loop in the cable to reduce stress on the cable from the movement .Before I take the plunge, I would appreciate the voices of experience and any feedback you have to offer. Thanks for your help.Gary WyngardenS/V Shibumi H335
