I installed a Raymarine RD218/C70 Classic MFD back in 07. I had to cut the radar cable because the connector is too large to fit through the pedestal guard and into a Navpod. It’s a 90° connector and it’s just too big. The radome is mounted on the mast. I used an extension cable up the mast which I step it each winter. I know they don’t recommend cutting but what else could you do? I used adhesive butt connectors for the power and soldered the others. Worked fine but last season I lost the screen twice, it went blank with vertical lines? It could be an electrical issue because the first time it happened I lost my alternator (pulley) and assumed I was getting voltage fluctuations. It happen one other time but seemed to worked fine after that. I recently decided to pull connections apart to inspect. I plan on using a Euro style terminal strip (separate post) instead of soldering the connections as I’ve heard this is where it would/could fail.
I checked continuity between each wire to it's female pin #'s in the connector body. They all checked good accept the Azimuth+ #12 violet. I cut the wire back a little and still no continuity. Is the connector defective? This is the 90° connector that attaches to the C70. Anyone know who makes these or are they proprietary?
I am not a connector expert but I don’t think this has anything to do with the screen issue but I think I should have continuity. These cables are obsolete.
Any thoughts? What is the function of the Azimuth?
