Draining and replacing are different tasks
They are 2 distinctly different tasks.Draining is the removal of water that has been separated from the fuel, from the bowl. You do that by loosening part way the screw on the bottom of the bowl, then you unscrew the recessed screw on the top of the bowl. This top screw is often made of plastic. Let it drain into a cup and look at the content. Water will drain out before the diesel. If the cup contains water, keep draining. If the cup contains both water and diesel, you can stop draining. Tighten both screws, and start up the engine to refill the bowl. Be careful with the plastic screw, don't over tighten, since it may break off easily.I try to drain the bowl every month or so. Depending on how much water you may accumulate in the fuel tank, and the quality of your fuel. Keeping the fuel tank topped off will help eliminate condensation, thus less water.This task is sometimes messy, so I save up large empty soup cans for this job.As for replacing the filter, it is pretty straight forward. Replace it when the filter gets dirty, saturated, and it could be a bit slimy too. I do that about once a year.
