Remember to close the fuel shut-off...
John,I've never had any problem getting the R15P. I bought my last one from marinedieseldirect.com.I believe the manual for you engine has instructions on changing the filters. If you have the manual you may want to refer to it.Close the fuel shut-off valve on top of the tank because otherwise fuel will continue to flow out of the filter housing after you unscrew the filter. Have some rags on hand and a bowl to put the old filter in after you remove it. If your filter is mounted under the afterbirth, as mine is, it will be almost impossible to remove without spilling a little fuel. The best thing I've found is to pull a small plastic bag around the filter from underneath. That way most of the fuel will be contained in that bag as you remove the filter.After installing the new filter be sure to prime it with the little finger pump on top of the housing. It is the small round knob that you unscrew with your fingers and them pump until the filter fills with fuel. Remember to screw the pump back down when finish.This is a good time to replace the fuel filter on the engine too. Don't forget to open the fuel shut-off valve, and then you'll be ready to go.
