Racor 500 fuel level
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
Hello all! Recently changed fuel filters and have noticed when I keep rechecking primary filter the fuel in the bowl is not at the top. I have topped it off 3 times so far over a matter of 3 weeks. Never noticed this before as have never checked fuel levels this often..... At first I thought it was just filters absorbing fuel. Do not ever have problem with air in engine and also replaced fuel pump in 2012. I tightened all clams in hose leading from tank today.......
Any advise or opinions?
7,446
Alden 50 Sarasota, Florida
Re: Raco 500 fuel level
Did you move the filter and is it below the level of the tank bottom?
WayneH
Tartan 37 287 Pensacola, FL
I think you have too much alcohol in your fuel and your clams are loose again.
I'm sorry. I just couldn't resist.
It does sound like you have air coming into the fuel line. And tightening the clamps should have solved your condition. The other leak point is the tank connection.
But is sounds as though your system is robust enough that you are rejecting the air bubbles at a different location. I realize that each engine manufacturer does it differently but my engine has an air bleed/fuel return on top of the secondary filter. When I replace the Racor filter, I just turn the engine to ON and let the fuel pump (electric) run until I hear a steady stream of fuel returning to the tank.
I hope this helps you.
Feb 6, 1998
11,709
Sounds like a gravity issue. Fluids are self leveling and some may be flowing back to the tank.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
if the filter is higher that the fuel tank why not run a fuel line that has a high loop above the filter in it between the tank and the filter or would that trap air in the line...
Hunter 37 C sloop Punta Gorda FL
My Racor 500 is above the top of my tank. Never is full to the brim, but never down more than 1/4" or so. I concur, some flows down hill, but if connections are tight, then vacuum limits back flow.
NYSail
Jan 6, 2006
3,145
I have had the filter in the same location for 6 years now and I've never had any problems in all sorts of crazy seas. Though I am going to check the level of the filter with the tank this weekend and move down.... Why not.
As always thanks all for the great advise!
NYSail
Jan 6, 2006
3,145
Btw Wayne I guess I'm a bit slow but alcohol in fuel and clams are loose....... What?????
WayneH
I knew it was a typo but I just couldn't resist. But I've also enjoyed reading this thread as I have learned something about my system while perusing the thread.
NYSail
Jan 6, 2006
3,145
Ahhhh those clams...... Love those typos! Glad you learned something as I always do from my posts here.
RichH
Feb 14, 2005
4,773
The first prime suspect for this would be a pinched gasket or O-ring on the Racor when you reinstalled.
This is especially the probability if you re-used the fuel-swollen (now much 'softer') gaskets/Orings.
If you used new gaskets/o-rings they must be 'lubricated' with clean fuel - to prevent such 'pinching' deformation when reinstalling (and over-tightening).
If you "un-tightened" any of the filter's or fuel system 'connectors', you could have inadvertently cracked one.
All the above conditions can easily lead to your system 'sucking air' ... but in this case just enough to displace a small amount of fuel and become a 'trapped bubble' in the 'topside' of your filter(s).
NYSail
Jan 6, 2006
3,145
All new gaskets properly wet with fuel prior to tightening. All clamps snug. Went to boat last night..... Filter is significantly above tank. The filter is slightly higher than the prior filters original installation. This weekend I am going to lower it to see what happens.
NYSail
Jan 6, 2006
3,145
So at boat and looking at filter and mounting options....... Not many. When reading the manual (novel idea!) it said when installing filter above tank to "install a check valve with light or no restriction when tank is lower than filter to maintain prime". What is general thought on these? Any experience before I go that route?
Beneteau 323 Annapolis MD
Is this situation actually causing some problem, or is it just the fact that the level is lower? I'd have to think by the time the engine starts and runs a few seconds that the full fuel level is back up to snuff.
NYSail
Jan 6, 2006
3,145
That's exactly what racor tech said. Told me to relax and that check value not needed unless I was having a problem. It only drops maybe 1/4 inch or so...... Just that I never saw before.
NYSail
Jan 6, 2006
3,145
Just as a follow up. I lowered the primary filter last week.... Fuel level in filter now stays at top..... Gravity issue.
Thanks all
[QUOTE="...level in filter now stays at top..... Gravity issue.[/QUOTE]
Sir Isaac Newton would be happy to hear that!
NYSail
Jan 6, 2006
3,145
Well..... Seems I need an apple on the head every now and again
