Mike Kinney
My wife and I took an 8 day, 450 n.m. sailing vacation that ended Friday On our last day out, we started hearing a clunking sound coming from under the cockpit floor that correlated with movement of the steering wheel. About 40 miles from home port, I decided I should investigate the noise. Because we were traveling in the ICW, there was no place to simply pull over and have a look. So, I removed the cockpit floor that covers the steering mechanism as we sailed. With the floor removed, it was easy to spot the problem. The end of the steering rod connects to the rudder with a ball and socket joint. The socket on the end of the steering rod had popped off of the ball on the rudder arm and was still partially working only because the socket was around the nut that holds the ball joint to the rudder arm. The clunking sound we were hearing was the steering rod knocking against the cockpit floor cover. Anyway, with the cockpit floor cover removed, there was no longer any force holding the steering arm socket on the nut above the ball on the rudder arm and the steering arm simply popped completely off of the rudder. Now life became much more interesting and exciting. With no steering and on a beam reach in a about 15 knots of wind, we changed course for the bank of the ICW. While my wife turned the wheel I grabbed the steering arm and tried to pop the socket back onto the ball on the rudder arm. However, the rudder arm kept wandering around aimlessly. Just before we plowed into the bank my wife was able to turn the wheel to coordinate movement of the steering arm with the movement of the rudder arm, and I got the socket back onto the nut above the ball on the rudder arm. A few moments later, driven by a generous amount of adrenalin, I was able to pop the socket back onto the ball. We managed to both avoid going aground and plowing into a power boat which was in the process of passing us. Has anyone else experienced anything similar with the rack and pinion steering? Can anyone explain why the socket could pop off and why I could simply pop it back on? This is a 1999 model 340 and I can't believe the ball and socket could be worn out already. If it helps, I have about 1,800 n.m. on the log. Thanks for any insights you can pass along.
