Quiet Mast?
100
Oday 272 Brownstown, MI - Lake Erie Metro Park Marina
Applied copper pipe insulation tubes into my mast to silence the Bell Clapping from the newly installed radio antenna coaxial cable! Good solution or mistake and future problems? PS: The tubes did eliminate the noise...
Cabby
Jan 14, 2011
39
Oday 25 Santa Cruz
Nice Post
Clever idea....Does the insulation absorb water? Did you run the wires throught the center of the insulation or is it enough that the insulation occupies most of the space inside the mast and the wires do not have room to slap around?
Thanks for sharing
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
That sounds like a good idea to me.
Nov 1, 2010
100
CABBY & Trinkka, Thanks for the positive comments... Insulation does not absorb H20. We just pushed the insulation up the mast and used duct tape at 6' section joints. Had to remove the one through mast bolt at the spreader and reinstall after application. Used 1/2" copper Insulation.
Regards, John
