Quick Question for Sam Lust
  • Thread starter Joseph Rheubeck
  • Start date
Joseph Rheubeck
Hello Sam, I tried to contact you through the Directory but the email was "Undeliverable" I have a 1981 33 in Groton Ct. I was looking at the Head Refurb that you posted and was hoping that you could answer a question. I have water trapped in the compartment under the fresh water pump. Did you remove the "deck" that the pump was mounted to when you installed the new tank? I'm trying to figure out if there is a limber hole which is plugged or if I need to drill one. If you removed the deck did you find a limber hole? Your project came out looking great. I am currently trying to decide between the PHII and the Lavac for the "Next Big Winter Project" Thanks and happy sailing on a great boat. J. Rheubeck S/V Cynosure
