Big difference between manufacturers.
Compare breaking strengths between Samson, New England, Bucaneer and several other brands and you will be surprised about the differences in breaking strengths. When looking at breaking strengths, note whether the figures given are for minimum, average or maximum breaking strength. That way you will be comparing apples against apples. If only one figure is given, the minimum breaking strength is approx. 80% of the average breaking strength. Just make the conversion. Also, make sure that you are looking at nylon and not polypropalene.
In the past, Walmart and Home Depot "anchor line" was a complete joke.
Also note that most manufacturers make 3 strand twisted nylon in 3 grades. there id a soft lay, medium lay and a hard lay. OK, so we can get a few jokes out of this.
Anyway, the soft lay is obviously the cheapest. There are less strands and slightly undersized but still in the same size category. Most boaters would want the medium lay if they knew there was a difference. The hard lay is more like a lariet and kinda stiff. More jokes, LOL.
If you go to hardware stores that carry 'anchor line' it is usually the soft lay (the cheapest cost to them) and unknown brand. Ask about the breaking strength and you will usually get a weird stare.
Tony B
