questions about my mac 22
It's a 1974 so I believe the swing keel is cast iron, have some questions.
1. is it just painted or wrapped in epoxy?
2. is it a bad idea to keep it in a slip (saltwater) because it'd rust much more quickly? how long do I have before I have to pull it out and restore it, just a guesstimate. right now it has a very small area of rust.
3. if I put it on the hard, is it sufficient to just hose it down after each outing?
4. the boat does not have a kick up rudder. when launching it, when should I put on the rudder? In the setup area where I raise the sail? will the rudder drag on the launch ramp? or is it better to launch w/o rudder, tie up boat to dock then put it on(I don't know if this is doable because the gudgeon is so down below water )?
thx
thx
