Hello i have a 1984 hunter 25.5 and i need to lower the mast on it does anyone know is the mast step on this a pivoting mast step? i took pictures of it here is the link http://s573.photobucket.com/albums/ss175/mattt6511/Hunter 25 mast step/?start=all
Also i have never lowered a mast i was told the mast on this boat isnt all that heavy probably between 80-110 lbs my plan was to remove the front pin from the mast step, remove the front stay from the deck and actually attatch it to a line that someone on land would hold as it slowly went down, remove both side stays, have someone sit on deck holding the mast and mast base then have two people on the port and starbard side of the mast slowly walk it down, while one person on land with the line attatched to the front stay lets out slack...
Does this sound right does this make sense??? All together it would take 4 people to lower the mast. would this work or would i have to fabricate some type of gin pole?? Thanks for any help!
