Jim Geiger
I am currently restoring my '74 H-25. One of the things which concerns me is the clearance between the rudder post and the fiberglass sleeve in the hull. I have considerable "wobble". I would like to correct the problem if possible. If anyone has had that problem and fixed it or knows of a fix please help me out.My other concern is the joint between the keel and the hull. The keel bolts are tight and show little or no rust. I have been told that it is normal for the keel to flex in the area of the joint and should not be a concern. I intend to use 3M 5200 to seal this joint. If anyone has been down this road and knows a better fix, or has some application techniques again please let me know.
