C
Carl
I purchased a custom deck organizer from Garhauer for the port side along with a triple crutch from Spinlock. I have been told you shouldn't drill all the way through the deck mounting plate but the bolts that came with the organizer are two inches long and the screws for the Spinlock are also to long. Do I get shorter bolts and screws or cut them down? If I use the bolts that came with the organizer and nut do I put an inspection plate in the headliner in the cabin so I can get to the underside? Has anyone else installed or had installed hardware on the port side installed on the plates molded into the deck? I purchased some shorter bolts and screws for the organizer and crutch but they only come in 1/2 inch increments so they will either go all the way through or have to be cut down. So any help would be great. I am going to us the new organizer and crutch for a rigid vang control line and two reefing lines.Another different question is, I have a ZSpar mast and what do you use to attach blocks to the holes in plate at the base of the mast so I can turn the lines to the organizer? The shackles on most of the blocks I see at West Marine are to large to fit through the holes, what else can I use?Carls/v Wind Shadow
