I recently purchased a catalina 250 that has a Panther Power tilt and lift. The zerk is corroded and needs replaced. It appears to be a 10mm. Once removed obviously grease will come out. How do you determine enough grease has been added? My previous grease experience has bleeder valves and I haven't seen one the actuator. I attached the mount for reference, the nipple is circled. Many thanks!
