I can't seem to get my LinkLite to auto-sync. I drain the bank down 15 - 20% or so, then switch the charger on... it's supposed to auto-sync once the battery is full, but it doesn't happen, even though the auto-sync conditions are met (13.2v from the charger, and no amps).
The result is that I end up with a full battery, but a battery meter that has not gotten all the way back up to 0 (maybe showing around -5 amps). I'm assuming that the LinkLite has an automatic CEF (charge efficiency factor) routine, which is not specifically mentioned in the manual but is present on all other Xantrex battery monitors, and that an auto-sync would cause this to be calculated. But because it won't auto-sync, the CEF is never calculated... and my AGM batteries, which charge more efficiently than flooded batteries, do not get "credit" for all the amps that are going into them.
While this is not a big deal when hooked up to shore power, and I know the battery is fully charged (and can manually sync), when out on a cruise for a week, it will become more of a factor, as negative amp hours accumulate.
I called Xantrex tech support, and after waiting on hold for about 30 minutes, the person who took the call was absolutely no help at all... I don't think he even knew what auto-sync was.
So, is anyone else having this problem?
--Michael
--Michael
