Question for Victron BMV-600S Battery Monitor Users
2,441
Catalina 310 Hingham, MA
Hi,
I installed a Victron BMV-600S battery monitor this year. I tried to program it this weekend but had some problems.
I would hold "setup" button for 3 seconds and then it would go to the programing menu. I would scroll to the "Cb" screen. Then I would press the "select" button but nothing would happen. The last "0" should have started flashing so I could set the battery capacity size.
Same thing with the "Pk" screen.
Any suggestions?
Thanks,
Jesse
Feb 6, 1998
11,703
Hi,
Any suggestions?
Thanks,
Jesse
Once in the Cb screen did you try pressing + or - ? Try to cancel out of programming, then do a manual re-set by pressing + & - together than try it again...
IIRC, when these first came out there was a post about the inline fuses being somewhat dodgy. The poster replaced the fuse and/or fuseholder and all was well. Don't know how this could contribute to your issue, but...
And further to MS's reply, with all computer-type stuff, reboot usually works, so if his idea doesn't work, disconnect and start over.
Good luck.
