Rob
Peggy we have constantly had problems with "bio critters and plant life" being sucked into our manuel PH11 head. They get clogged in the bowl rim and become a real stink. I have installed a screen on the outside of the boat on our through hull,,,but 1 time it fell out and another time it became clogged and was tough to clean as I had to go swimming..I was now looking at 2 possible solutions.1). to install an in line stainer with clear cupped catch and install under the head sink ,,,then I could check occasionally. and empty when full. OR2). Has anyone ever talked to you about installing a fresh water supply tank for the head intake???.....we have room under our V beth for a 20 gallon tank this would eliminate all intake problems since we would be using "Clean" water .We could refill anytime we are in our slip, this could also be attached to a "Y" valve in the event we ran out of supply tank water . It could be turned for raw water use..What are your thoughts???I know the inline strainer would be the cheapest solution.....We have been dealing with this for 2 years... we have a new holding tank and all new hoses 2 years ago.......but its the head that stinks and catches the debri...you can see it come out of the rim when you flush.PS. We are using KO in the holding tank which seams to do a fine job.any help would be appriciated.thanksRob
