Question for other C-22 fixed keel owners...
Matt
Where is the bilge pump mounted on your boat? Since my keel bolts are exposed underneath the table (cut a hole for inspection/access), I am thinking about slipping the pump there. The previous owner had it near the battery tray, but it appears to me that the keel bolt "compartment" is lower. Whaddayathink? Thanks.
Robert
Bilge pump
Mine is located more toward the back closer to the battery tray.
Randy
mount it low
Matt mount it low, and high,,,,my hose is mounted in the area under the floor at the keel bolts but the manual pump is located in the side of the cockpit floor area back under the tiller....I have used it and it works great..... My C30 had an electric mounted between the keel bolts and had an auto float switch....You want the pickup as low in the boat as possable......
