Great South Bay
The draft of the H33 will not be a major problem. You will be more restricted but there is still plenty of bay to sail.I am a member of the SBCC. We have members with drafts over 4 1/2 Feet. Windquest, a 46' Hylas, and CeeJ2 a 42' Whitby both have drafts over 5 feet and go into both Davis Park and Watch Hill.Watch Hill is easy just line up the lights as you enter the channel. There is severe shoaling on either side of the channel, but the channel is well marked, and if you keep the lights lined up you will not have a problem.All the slips east of the snack shop are deep.Going into Davis Park, leave the head buoy for Watch Hill and head straight toward the dock. Check your charts there is severe shoaling both east and west. Last fall some of the bouys were missing, several members bumped the bottom going in. But at high tide 4 1/2 feet is not a problem.Talisman can be entered if you come from the northwest corner of the Barret Beach dock. Split the southernmost bouys marking the entrance to the anchorage and you should have about 5 feet all the way at high tide. But go with caution. Note, with a draft over 4 feet you can not make it up the marked channel.John, if the draft of the H33 is the only thing holding you back.....GO FOR IT.Hope this helps.EdS/V Mistress
