Re: 2004 Hunter 36...
I am replacing the round gasket that goes between the bowl and the base and I expected a simple job - undo four nuts holding bowl to base, swap the gasket, and tighten down the nuts. I was surprised to find that the four nuts holding the bowl are on bolts that are not "captive" and turn freely.
It seems like I have to un-bolt the whole head assembly from the floor and lift/tilt it to get underneath the base to hold the bolt heads while removing the bowl.
Is this correct?
Is there a better way?
Thanks... Andy
Is this correct?
Thanks... Andy
