Question about a Simrad TillerPilot and GPS
25
2 C22 San Diego
Hi I'm new here
my question is... will a Simrad TillerPilot TP22 interface with a Garmin GPSMap 76?
so you can set a course on the GPS and the TillerPilot will steer you there... theoretically ;)
thanks!
Steve
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
If the Simrad TP22 has an NMEA 0183 interface, it will work with the Garmin GPSMap 76.
Using an autopilot slaved to a GPS is not a good idea IMHO.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
Other than the obvious problem of complacency followed by not keeping a good watch and running into something, why is it not a good idea? It can be a big help when singlehanding.
Oct 22, 2008
3,502
Generally, following waypoints blindly, without checking the boat's course made good, drift and set, and progress is a bad idea. If there is a strong current or wind, the autopilot may not compensate properly, and if there is a hazard near the route, it may bring the boat into danger.
For instance, on the following chart, say you're going from WP0062 to WP0007 on autopilot with an easterly wind. If your boat is making leeway, you may end up hitting the small Butler Flats Light, which is just wsw of the two buoys in the center of the chart image.
May 14, 2009
25
2 C22 San Diego
Thanks!
I'm real new to all this
I'm a pretty complacent guy and I've been known to run into stuff on occasion
maybe I'll leave em stand alone at this point
Oct 22, 2008
3,502
An autopilot is a very handy thing to have on a sailboat, especially if you single hand the boat a lot. However, Otto won't keep a good watch, or have the ability to warn you when he's about to do something really stupid... so you really have to take full responsibility when using one.
A couple of summers ago, I saw what was pretty obviously an autopilot induced collision. The Direction, which is a 65' professional lobster boat that sails out of New Bedford harbor hit one of the large green lit buoys that marks the New Bedford harbor approach channel. In fact, in my previous chart, it is the second green buoy down from the top of the chart. I was watching as the Direction, with no one in the bridge, came along and NAILED the buoy well enough to knock it down and run over it. They broke their bowsprit off about half-way down... and had to lose a week of fishing time during the prime part of the season because of it. They were lucky in that Direction is a heavy steel fishing boat that could take the impact of the buoy rising up under the boat and not be seriously damaged. A second after the large "BONG" of the collision, we saw someone pop up onto the bridge and run across the bridge to the helm.
Instead of anyone being seriously injured or losing the boat, all that happened AFAIK, is that these guys went a week or so without getting paid... if they're not fishing...they're not making money. In a smaller sailboat, people could have been severely injured in such a situation.
