Hey All
I'm in a quandary. I just took possession of a very well kept Hunter 26 and it came with a 2014 Honda 9.9 manual start O.B. The P.O. told me that it did not have an alternator (he thinks) but as I was running things down on the electric system I found a set of wires coming from the O.B. and going to the batteries. I'm thinking that maybe I just got a bonus... so I disconnect the plug at the O.B. and measure the voltage coming off the motor while at idle... ZERO volts! So I dig out the owners manual and it says that if you are getting no current off of the alternator, you should check the fuse... I open the cowl and find the fuse box... fuse looks fine.... I also find the spare fuse and just to be sure I swap them. Still no joy.
So here is my question... Would Honda go to all of the trouble (and expense) to install of the electric wiring and circuitry for a charging system if the O.B. does not have an alternator? Did Honda even release a 2014 9.9HP w/o a charging system?
I would feel like a HUGE dope if I took my O.B. to my mechanic and asked him to look at the charging system only to have him tell me a $100 later that my O.B. does not have a charging system.... :-(
Any other ideas of how to run this down?
Thanks in advance
r
Thanks in advance
r
