Question about 38s5 headroom
764
Hunter 376 Pensacola, FL
Are there any 38s5 owners out there that can tell me what the headroom is belowdecks? We're starting to consider what our next boat might be, and one of the desired characteristics is being able to move about down below without having to constantly hunch and duck. I'm six feet tall, so we're looking for a minimum of 73 - 74" into the forward cabin.
Apr 27, 2010
969
Beneteau 352 Hull #276 Ontario
A 1994 38s5
Dimensions
LOA: 38 ft 5 in
Beam: 12 ft 4 in
LWL: 33 ft 0 in
Maximum Draft: 5 ft 2 in
Displacement: 14550 lbs
Ballast: 5952 lbs
Bridge Clearance: 55 ft 0 in
Headroom: 6 ft 2 in
May 28, 2009
764
If you think you're being helpful, then thanks, but I've already downloaded the spec sheet from beneteauusa, and have looked at the various online specs. What I want to know is what the REAL headroom is belowdecks, as in how far forward does that 74" carry? Simply saying there's 6'2" headroom only means that there's at least one spot, probably at the bottom of the companionway, where there's enough room for me to stand without leaving scalp on the overhead.
