Steve Young
I've only had the boat for about a year and I'm in the process of replacing a lot of stuff. Recently I tackled replacing all of the hoses to and from the molded holding tank. All I did was just make and install new hoses just like the ones that were there when I got the boat. After completing the job, and in the process becoming more familiar with the system than I really wanted to be, something doesn't make sense.I think that a previous owner may have put the whole system together backwards. The way it is now, the inlet from the head is at the bottom, conical-shaped portion of the holding tank and the pump-out hose connects to the top of the tank, right next to the air vent. Shouldn't this be the other way around? This arrangement seems to work ok, we had it pumped out several times last year with no problems, but it just seems to me that it should be the other way around.I'd appreciate any help you can provide.Thanks, Steve
