Just one thing.....
You can only get this boat, this design (Cherubini), by purchasing one used. Everything produced after 1983 was on an entirely different approach. Newer designs are built lighter, larger interiors and very wide stern. Those are nice for changes for those who want them, however, as Steve has mentioned.. the Hunter 33 (79-83) sail well in all conditions. We have never been as pleased with ours as the last time we sailed her. We have now owned ours for 23 years and everything that has ever been done to her... I've done myself. This will mean alot if and when we make it to the coast to go cruising, I know this boat inside and out. I might also mention that another area to check for problems is where the pedestal is mounted, the edges of the glass are not sealed where the steering cables go thur the cockpit deck. There is a five inch opening under the pedestal. If water has gotten in there, it's possible some rot has taken place in the plywood core. I had to replace my entire core in the cockpit deck due to water damage, but it's stronger than ever and I sealed (glassed) that opening to prevent it happening again. Hey Steve, our boats are the same year model!Good luck with your search for YOUR perfect boat.David Underwood
