Fast Signs or equiv....
Our company has a vinyl sign division so I conned the guys here into cutting our name,,,and they gave me tips on installing.You will need minimal tools,,,an exacto knife, a small squeegee or putty knife, masking tape, and a spray bottle.Find a local sign shop...Like David said,,,,Quick signs, Fast signs, etc,,,they are everywhere...most will work with you on the design....and show you on the computer screen before cutting....after they cut the logo here's my tip and from our companies sign guys.....clean the area to be applied....reg soap and water is fine......fill a clean spray bottle with a mixture of dish soap and water...not too much ,,maybe 2 squirts for a 10 oz bottle.. you want a silky mixture...shake....spray the area on the boat,,,but do not soak it...a slight mist. ...take your sign from the shop...it will be on a self adhered release sheet.....tape the top edge to line up with the boat rail...(if you want it parallel..an angle well place it where you want.).....Now starting from the top pull the release paper back and start applying the logo to the boat from the top....move slowly...the idea of the soap water is that it will give you a little wiggle room if you mess up......continue pulling and use the squeegee to remove any water/ air bubbles...and the exacto knife to help in case you fold part of a letter...its easier to use than your fingers....Keep pulling until the entire paper has been released...its easier and you will get less accidental uplifting if you pull the paper at almost a 180 degree angle keeping the release paper close to the boat and not pulling away from the boat..... go over the letters and make sure you have no air bubbles or soap bubbles...if so squeegee them out if you can't take the exacto knife and pop the bubbles and then squeegee the liquid or air out....Most important ...take your time ....Its definitely easier on the hard but I have done it on water also.....just watch the wakes.Good Luck!...don't forget to perform Vigor's nameing ceremony!
