Steven Sommer
Hi Peggy,The tank I'm installing is directly beneath the pumpout fitting on the deck. I've been puzzing over the possibility of pumping the tank out from the top rather than the bottom (and avoiding the running of hose down and around the tank). On thought was to insert a PVC tube into the tank that seals at the pumpout connection - and is cut at the bottom to strategically allow material to flow. It would probably have to be adhered to the bottom of the tank somehow to avoid damage as the contents slosh around.Have you ever seen such a setup?Thanks!Steve
