Jerry Holloway
Peggie, my Hunter '86, 40' has two heads. The aft head had to be replaced after I replaced the seals in the original only to have the pump body develop a 3" crack. Now the forward head (original)pump is sticking. I have used a West Marine pump lubricant which helped but the pump still sticks once it is left in the down position. It takes two hands to free it. When pulling up on the pump handle there is no fresh water entering the bowl (small lever handle is in the up position). I loosened the hose clamps, with the thru-hull open and there is intake water present up to the head. The only thing in the intake hose is a "T" fitting with a screw-on cap.The fitting is on both head intake hoses. I don't know what the fitting's purpose is. The fitting is open and does not appear to be causing the problem. Any suggestions?thanks very much for your help.Jerry
