Tom Martin
Peggie,I spent five hours yesterday rebuilding the head in a Beneteau (to no avail), then unclogging a blocked discharge line (between the Jabsco head and the Y valve). Nasty - hope to never need to do that again!So today (in hopes of not repeating the disaster) I turned to one of your articles and read "flushing 101", and discovered that we haven't been flushing the stuff all the way to the holding tank each time. You said to determine how many strokes it takes to move the "contents" all the way to the tank, on the "dry bowl" setting (if I understood correctly), and then pump that many times every time.But it seems to me if there is, say a gallon of water etc in the head when the valve is switched to "dry", you could pump forever and not move it to the tank (at least on my boat), because the discharge hose rises (in the lazarette) about 3 feet above the head before it hits the y valve; the hose from the Y valve to the tank then dives back down to "bottom of the lazarette" level on its way to the holding tank, then climbs back up to enter the tank which is 2-3 ft above the head. The system is vented of course, so how can that gallon of water+stuff ever get pushed uphill that far? Unless there is new water being pumped into the discharge hose (wet bowl), it seems to me the "stuff" is just going to sit in the vertical hose behind the head (and gurgle around a bit as you pump..). Following this logic to its conclusion, I think that with a system like mine you will never end up with only water in the lines - the "stuff" will just get more diluted the longer you pump on wet bowl. If this is the case I guess we should just pump on wet bowl for 8-10 strokes anytime there are solids in the bowl, to at least encourage them up that hill. Sure will be pumping out the holding tank more often though.Am I missing something? I really don't want to unclog that hose again...........Thanks for your help!
