F
Francis Morton
I am going to install a roller furling unit. The pulpit is open at the top rail and closed at the bottom rail. This bottom rail comes to close to the forestay (about 2" - 3"), not enough room for the drum on the roller furling.I did not want to hike the whole assembly up. The asetetics of having the sail that high off the deck is not appealing, not to mention the actual area cut from the sail will. I was wondering if there is a retrofit idea for the pulpit.
