Mike Andersen
Hi All, and thanks to the many helpful responses from previous posts of mine.H27 1980Where the pulpit goes thru the deck, it leaks. The stern two bolts of the pulpit are accessible from the V berth. The fore two not. There is a piece of plywood at the fore part of the V berth. I tried to remove it but it just didn't want to go. From past experience I've learned to ask questions before applying force. Any suggestion would be welcome.Is there another way to access the front two bolts?I plan to take all bolts out, apply a generous amount of silicon (clear) and rebolt the pulpit.While I'm thinking of the pulpit I've got another question. The jib is often pressing against it. Can't be good, the constance pressure could easily be responsible for the leaks. Is there a technique to avoid the situation?
