Pulling new wires
F
FP
What is the best route for pulling a new AC circuit for a battery charger. I plan to put the charger down next to the water pump.
Rod Leonard
Battery Charger
FP. I put a battery charger in mine down in the starboard storage compartment. Mine hangs on the wall and the wires run through the chase directly to the Batterys. Works very well there.It's dry and doesn't junk up the engine compartment. Also years ago I split the 120 connection and put in an additional circuit breaker and 120 outlet, in that storage compartment. That's where I plug in my Charger & Refrig unit, ahead of the control panal. If your using a 20 amp cord you have to watch your amp draw. Nerver had any problems in 12 years.
