Brunson Russum
The Universal 5411 on my 1979 Catalina 27 has an oil leak. Some from the oil pan and some from the flywheel area. The oil pan gasket is not a problem. The leak at the flywheel is a concern. I have discussed the problem with a local marine mechanic that I have worked with before. He indicated that the engine would need to be pulled to service. He did not think that fixing the leak was a particular challenge. He was concerned, however, about the potential cause of the failure. I don't know if this type of problem is normal for the age of the engine. I would like to know what the alternative causes might be and how involved the repairs could get. As with most sailers, budget is an issue. I can do some work myself and am interested in learning more about the engine. I am a bit intimidated about dismantling the engine. Any assistance would be greatly appreciated. Thanks, Brunson Russum
