Pulleys at base of mast
O
Ohio Ron
When I finished rigging my mast in place I noticed that the double pully at the base of the mast (on the deck);that changes the direction of the main and jib sheets from vertical to harizontal; has come loose on one side. The shaft that the pullies rotate on has come loose on the bow end. Does anyone know how the get it back in place? I can't access it from the deck side or the cabin side. Help!!!
Mar 21, 2004
343
Hunter 25.5 Carlyle, IL
Mast baseplate
I think the only way to access it is be dropping the mast and removing the mast baseplate.
