Quick question for all you out there...
I have an '84 C30, M25 engine, Hull #3687.
My electrical panel is factory installed on the upper port side, and has a key for power, push button for the glow plugs, and a pull switch for ignition.
I'm in need of replacing the pull switch for ignition, however i didn't see a replacement on Catalina Direct, any ideas of a replacement?
