A
Alan
Has anyone looked at installing an AC generator on a 3 cylinder Yanmar diesel engine?. I have been looking at 3-4 KW diesel with a price tag of $4-5k. I investagated adding a 3-5 KW geneator to the Yanmar. If you get a 3600 rpm unit the size is small. Adding an electric clutch and generator the price tag was around $1k. You would have to be docked or anchor and run the engine at a certain RPM to get the right speed at the generator which depends on pulley sizes. It sounds like a good solution because you do not need to add another mechanical system. I plan to run my central A/C which should be a 16,000 btu/hr cooling system. Any experience out there ??????
