PSS Shaft Seal
K
Kim Efishoff
I had a PSS Shaft Seal installed on by 1977 Hans Christian 38 two years ago. To tell you the truth, I don't think it's leaked a drop. However, I uderstand that when a PSS Shaft Seal fails, it's catostrophic. That is, unlike a packing gland which starts as a slow drip and develops over time into a trickle, the failed PSS allows an onslaught of water to enter the boat. 1) Is this true? 2) Should I have some kind of emergency wrap aboard to stem the flow in event of failure? If "yes", what would you recommend. One additional question: When I torqued the boot at the seal ring when attempting to tighten the hose clamps, water squirted past the seal ring. Is this normal? Thank you for your answer. Kim Efishoff
K
Kim Efishoff
HP, I appreciate your comment. However, there is nothing in the archive that addresses the questions I asked under "stuffing box". Kim Efishoff
G
Guest
Kevin @PYI
Would be interested to hear what you have to say about this Kevin!
Bob Carlton
I have one and
I don't think it has leaked a drop since installation 1.5 years ago. I also would like to hear Kevin's comments.
Randy
Kevin
How can you tell how much pressure to apply by moving the metal collar aft? Is it OK to just be able to move the bellows open about 1/2 inch? Is it necessary to have a drip for lubrication? Thanks.
