PSS Shaft Seal Specs
Mike
Does anyone have the specs for a PSS Shaft seal for a '86 Catalina 30. It is the stem size I am looking for...Thanks
Ron F.
pss shaft seal
I own a C27. The Outside diameter of the hose around the prop shaft tube is 2". When I removed the stuffing box the O.D. of the tube was 1.5". 1/4" wall is typical for the hose. Measure the O.D. of the hose and determine the wall thickness if you can. My prop shaft is 1". Hope this helps. The PSS shaft seal looks like a real good upgrade. A little pricy but I think it is worth it. I hope to install one on "Temptation II" this spring.
