I'm posting this as a curiosity item for others to comment on. I've had a PSS shaft seal on my boat for 10 years with an estimated 700 to 800 engine hours. The seal has worked flawlessly, and I have never noticed any leakage. This is the self venting design via a vent line on the carbon element.
I finally decided to replace the bellows as purely a preventive measure. PSS recommends every 6 years or so. When we took the seal apart I was very surprised to see the wear pattern on the carbon and the SS element as shown in the pictures below. I would have expected both faces to have a very clean mirror finish but the did not. A close look at the carbon face indicated that only about 1/2 of the face surface area was in contact with the SS face. Also the SS face had some type of contamination on it perhaps from the carbon element. Also the carbon element appeared to be chipped on both the inner and outer edges. The outer edges also seemed to be peened over as though they may have overheated. Again I would emphasize that the seal never leaked. I suspect that any potential failure would shown up as a small leak and certainly noting catastrophic but I am curious as what others might think about what might have caused the seal to wear like this.[/ATTACH]
