James Marohn
Howdy all!<P>The other day we suddenly lost shore power while we were moored at a marina. I'm suspecting what happened is that we blew a fuse or threw the breaker as we had quite a number of things drawing AC when it happened.<P>We checked the breaker switch where the shore power was plugged into, it was on. Still no AC.<P>As it is, I'm guessing that there is a fuse and/or reset button and/or breaker switch 'inside' the power inverter on the boat. But I'm a bit nervous going through the process of un-mounting the power inverter and cracking it open. I am not and electrician afterall.<P>The power inverter is a PROSine 1000. Has anybody else worked on one of these things? Any other suggestions/recommendations?<P>Any input would be highly appreciated. Thanks!<P>Perelandra - V32James Marohn
