Hey All, I'm approaching 1000 hrs on my 3ym20 (2007 Catalina 309). I do all the typical routine maintenance (oil and filter, fuel and air filters, coolant changes, impellor, changed mixing elbow, etc.) Manual says I ought to be doing a valve adjustment.
Question: Is there any issue with putting off or not doing valve adjustments if engine is running really fine? In other words, does it actually cause any damage...or just a possible slight loss of performance?
Seems to me as valve train wears, valves might not be opening quite as fully, and I might lose a small bit of performance. But I don't think wear tends to make valves too tight (which of course might cause one to burn a valve)? I hate to tear down into the engine when things run so well, giving me an opportunity to cause issues....
thanks for any insight, Dave in Charlotte Harbor.
