Sorry Dennis and RichH, but you're analysis is
flawed. Dennis: An airplane stops its prop from spinning by feathering the prop, thereby reducing the surface area to essentially that of the leading edge of the prop, and therefore is totally unrelated to the problem at hand (that's why people purchase folding / feathering props).RichH:A stationary, NON SPINNING prop has an apparent surface area that is proportional to the actual surface area projected to be parallel to the flow of the fluid (this will be somewhat less than the actual surface area, but MUCH MORE than the surface area of the leading edge of the prop.A prop that is free wheeling can't spin any faster than the water will turn it (conservation of energy and momentum etc), and it will be less than that depending on the friction of the transmission, bearings, etc.) (otherwise it will be providing thrust, not drag).If a prop is spinning AT THE SAME SPEED as the water, it will have essentially the same apparent surface area as the leading edge of the blades. To understand this, take two streams, both the same distance from the center of the prop, but next to each other (say 1 mm apart). If the prop is fixed, stream 1 will hit the prop and be deflected. Stream 2 will hit the prop slightly later, but 1 mm ofset along the same concentric circle from the center of the prop (the prop does have a pitch after all), but when it does, it will also be deflected. This is form drag.If the prop is free to rotate, when stream #1 from above hits the prop, it is deflected slightly, and pushes the prop away by inducing rotation. The second stream may or may not still hit the prop because the spin induced by stream #1 has moved the intended target away. In this fashion, a free spinning prop can aproach the apparent effective surface area of the leading edge of the prop, but not actually reach this ideal due to system friction.Before you theorize, perform the experiment or do the math. A feathered prop has the least friction / drag, a free spinning prop has more friction / drag than the feathered / folding prop, and a fixed prop (assuming the same prop / boat combination as above) will have the most friction / drag.The ONLY case where a fixed prop may have less drag than a freewheeling prop is if it is mounted in an apperature where the deadwood around the prop essentially hides the prop from the water flow as long as it is alligned with the hull / keel.To convince yourself of this, take a toy windmill / whirlygig. Tape the spinner (prop) to the shaft to prevent it from spinning. Mount it in a block of wood. Glue the wood to the roof of your pickup truck. Drive around your neighborhood at a set speed. Measure the angle of deflection between the shaft and the block of wood using a protractor. Now, un-tape the whirlygig and let it freely spin. Repeat the experiment. Better, use two whirlygigs. Tape one and let the other free-wheel. Reverse the tape job and repeat.You will find that the free rotating whirlygig will have less deflection in the shaft than the locked whirlygig. That is related to drag caused by the whirlygig prop and is exactly the what we have been discussing.I reiterate. A free wheeling prop will ALWAYS have less drag than a fixed prop. A free wheeling prop may or may not be suitable for your boat based on engine, transmission, bearings, etc.And Liam, I'm a good enough helmsman to detect when a change in sail trim (or prop rotation), has affected the speed of the boat. I suspect that you are too. Perform the experiment before you trash it. It works EVERY time. (but you must be below hull speed as prop drag is minimal when compared to other forces acting on your boat and probably undetectable)SteveAlchemist C-30T #4764Alchemist C-320 #909
